$10,000 Service Estimate from Dealer? or should I try my luck somewhere else? [2001 A
Old Mar 3, 2016 | 04:21 AM
Timmy Reilly's Avatar
Default $10,000 Service Estimate from Dealer? or should I try my luck somewhere else? [2001 A
I received this service estimate for my 2001 Audi A4 at a dealership after a check engine light went on and I needed a new key programmed.
What do you think?
Additional items noticed during inspection:
  • Valve cover & camshaft tensioner gaskets leaking ($1375)
  • Engine mounts collapsed ($1110)
  • Pollen filter dirty ($95)
  • Crankcase breather hose leaking ($475)
  • Coolant reservoir leaking ($190)
  • High pressure power steering hose leaking ($610)
  • Both catalytic converters failed ($3600)
  • Both left & right front outer cv boots torn ($495 each)
  • All 4 door speakers ($1450)
Plus original estimate of $398.45 (for oil change, check engine light diagnosis, key programming, and key battery)
Should I drop the coin?
Take it to different place?
Find a new car?
My current plan is to call around tomorrow for some more estimates.
Any ideas, experience, wisdom to share?
Old Mar 3, 2016 | 06:57 AM
dave944's Avatar
I don't call them the "stealer" for nothing... Find a shop that doesn't charge $150 an hour. Plus you can get the parts (most of them) in another, less pretty box, from half to a third less. I can tell you that the valve cover and tensioner gasket sets can be had from Blauparts for around $100-150. Might as well do a timing belt change when you do that. Unless they have to drop the engine to change the mounts, $1100 is just effin' crazy. I just replaced the two outer CV joint boots on my 03 A8 since I was also putting new bearing assemblies on it. But since you can more than likely remove the drive shafts without breaking down the front suspension (which would then require a re-alignment), you can get a couple of boot kits from Blauparts ($25 a pop). It'll probably take an hour per side. All 4 door speakers? Dafuq does that have to do with the Check Engine light? Sheesh.... Rip-off
$10K in repairs.. Doesn't that effectively "total" the car?
Old Mar 3, 2016 | 12:59 PM
Thanks for the advice. I'm going to make some calls today. I'll keep you guys posted.
Old Mar 5, 2016 | 11:19 PM
SethRogen's Avatar
A lot of those things are fairly simple DIY that will cost a fraction of the price. If you can't DIY then find a Facebook page of local VW enthusiasts and ask them who they take their cars to. Chances are they are MUCH cheaper and probably just as good, if not better, techs. I had a job quoted at $2500 from the stealer and $1000 from my local shop who I trust far more than the local Audi dealer. If none of that floats your boat then sell the car and find another set of wheels. $10K will go a long way in buying a decent replacement.
Old Mar 6, 2016 | 09:53 AM
randomid123's Avatar
Wow, $10,000.
Old Mar 6, 2016 | 07:57 PM
dave944's Avatar
I can't believe they even had the nerve to give him the estimate. As if......
Timmy Reilly
Apr 9, 2018 07:42 AM
kakashisan
Feb 25, 2008 09:47 PM
AudiA4Girly
Dec 17, 2007 02:43 PM
