02 Audi a6 4.2 Window Issue
Old Feb 12, 2016 | 06:17 PM
cmoii's Avatar
Default 02 Audi a6 4.2 Window Issue
Today a problem occured when i turned on my car to go to lunch. When i turned the car on the rear passenger window rolled it self down. I thought this was weird so i go to roll it up and its not working. Then when i turn my car off and let it sit for a few seconds it allowed me to roll it up. Not sure what is wrong, but every time i start the car now the window rolls down.
Old Feb 12, 2016 | 06:39 PM
cmoii's Avatar
BUMP
Still need help, now when i turn off car the window wont roll up unless i use the way to roll the window up when you put the key in the door
Old Feb 12, 2016 | 06:45 PM
dave944's Avatar
Check for something in the switches on both the driver and passenger doors. A piece of debris or some conductive fluid could have been spilled into the switch at some point. You could disconnect the plug from the back or the switch on the passenger door to see if the issue goes away. If it does, there is something wrong with the switch. More than likely it's something that has mechanically gone wrong with the switch or just needs disassembled and cleaned.
Old Feb 13, 2016 | 12:56 AM
cmoii's Avatar
Thank you for the input, do you think pulling a power window fuse would allow me to run my car without the window rolling down until i have the time to take a look at the switches?
Old Feb 13, 2016 | 11:32 AM
dave944's Avatar
You can give that a shot. But there may be something else (probably not an important something) on the same circuit also. Won't hurt to try though.
Mr.Gerb1k
Sep 28, 2013 11:00 PM
h4x0r
Dec 31, 2011 12:20 PM
toyolla86
Jan 2, 2007 09:03 PM
samofny
Aug 8, 2005 02:28 PM
