1999 A4T clutch sliping, what to do?
Old Oct 27, 2007 | 01:04 PM
rutt111's Avatar
Default 1999 A4T clutch sliping, what to do?
Hi, I bought 1999 A4 1.8T with a manual transmision two months ago, the person who I bought it said that he just replaced the clutch, because was sliping. I test drive it and it looked fine.Few days ago I was trying to pass some cars on the road and when I accelerate a little harder, I sawthat my RPM is going up but the car do not accelerate a lot. Is it any body knows, if anything else can bedone exept replacing clutch? What else can couse sliping?
Thanks a lot for your help.
Old Oct 31, 2007 | 06:33 PM
tHe kNiGHt FaLL's Avatar
Default RE: 1999 A4T clutch sliping, what to do?
leaking rear main seal... leaks oil onto the clutch disc allowing it to slip.
can chage the clutch as many time as you want...
3m makes this rear main seal sealer... it pretty much swells the seal...
costs maybe 4.00... and if it goes away then you kno your issue... if not...
trans input shaft seals can leak and slip... and improper install can slip.
i'd try the 4.00 fix... if not... gonna have to take it in somewhere
SmogSUX
Jun 6, 2012 07:12 PM
mowgli25
Jul 10, 2010 10:22 PM
audiky
Feb 18, 2010 04:22 AM
Jessie2k
Oct 11, 2008 03:05 AM
Jessie2k
Sep 11, 2008 12:37 PM
