2001 Allroad will not start need help please
My allroad was running fine no problems or symptoms of any kind. Parked it and when I returned about an hour later it would not start. The engine would turn over well but it would not fire.
I connected the Vag com and it came up with 13 faults in the central convenience module (mostly relating to the alarm).
Has anyone seen this before and should I be replacing this unit or is there something else going on?
The vag com results are listed below.
Thanks for any help it will greatly appreciated.
VCDS Version: Release 908.2
Data version: 20100326
Friday,21,December,2012,14:55:37:19856
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 H
Component: 2.7l V6/5VT G 0002
Coding: 05752
Shop #: WSC 02325
WAUZZZ4B92N020246 AUZ7Z0A1892396
1 Fault Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 X040
Coding: 25500
Shop #: WSC 09999
No fault code found.
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 05832
Shop #: WSC 00010
13 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
01562 - Right Rear Door
59-00 - Can't Unlock
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
61-00 - Won't De-Safe
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00030
Shop #: WSC 02325
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 H
Component: symphony II NP2 0005
Coding: 00001
Shop #: WSC 02325
End ---------------------------------------------------------------------
76 77
Coding: 05752
Shop #: WSC 02325
1 Fault Found:
Coding: 25500
Shop #: WSC 09999
Coding: 05832
Shop #: WSC 00010
13 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
35-00 - -
35-00 - -
Coding: 00030
Shop #: WSC 02325
Coding: 00001
Shop #: WSC 02325
ride1157
Jul 8, 2009 04:17 PM
