2005 S4 Cold Start Problem
Old Apr 16, 2015 | 01:41 PM
BillHarris's Avatar
Default 2005 S4 Cold Start Problem
I have a 2005 S4 6spd. Gradually over the last several months when I first try to start the car after its been sitting for a few hours nothing happens. I press the clutch and turn the key and nothing, the screen says "depress clutch blahblah to start". The clutch switch has been replaced 2 times in last 16 months from the dealer yet that has not resolved the issue. Help Please
Old Apr 17, 2015 | 10:42 PM
tomattsi's Avatar
After you had the switch replaced, did it work fine? If so, bad switch. Else, wire/connector?
Old Apr 17, 2015 | 10:47 PM
BillHarris's Avatar
No it still does it. Especially in colder weather
Old Apr 17, 2015 | 11:58 PM
bradtyler02's Avatar
Probably a starter. I had the same thing happen on my '06. To check, climb under the car, disconnect the solenoid wire (the small one, not the big ones) and check for 12VDC between that wire and a ground while a friend tried to start the car. If you have 12 volts there, you know everything is working up to the starter. If not, then trace it back from there.
Don't bother taking the start to auto zone or the like to be tested. I had two bad starters test just fine there.
Old Apr 18, 2015 | 10:19 AM
tomattsi's Avatar
I would think towards starter also, except that the controller is telling to push the clutch in, which is needed to engage starter. Does the panel display press clutch every time you start the car, even if the clutch is in and the car starts(warm weather)? If it does, then most likely starter. I don't have a manual transmission, so I don't know if this displays every time, whether the clutch is in or not.
My car doesn't start in cold either, but that's another matter ;-)
Old Apr 18, 2015 | 08:47 PM
It will display every time, regardless of the clutch position.
Old Apr 20, 2015 | 10:12 AM
tomattsi's Avatar
It then sounds like the clutch warning is just a reminder, like mine says depress brake to shift, no kidding.
I will say your starter is the issue. You can verify like the other post suggested by checking to see if voltage is making it to it, which I'm guessing that it is. I thought there is also a relay for the starter. If so, begin at that point.
DaPrezOH
Mar 18, 2013 11:55 AM
Navidio
Feb 1, 2012 03:45 AM
Big Diesel A8L
Jan 4, 2010 01:04 AM
critical
Apr 14, 2009 01:47 PM
Arnold K.
Jan 14, 2009 03:30 AM
