'99 A4:Intermittant ABS and BRAKE warning lites
1999 A4 Avant Quattro 1.8T:
Last 3 weeks the ABS light will come on briefly, accompanied by its 3 beeps, followed by the BRAKE warning light, then it all goes off. On a FEW occasions they've stayed on as long as 5-10 minutes.
Audi tech said only problem with continuing to drive under those circumstances are: (1) ABS may be out, and (2) brake lights may not be working.
Brake lights ARE working, I found out, but I haven't had any opportunity to test the ABS while the warning lights are on.
Tech and I feel we need to wait till it all stays on, so that it can be diagnosed more easily.
Any experience with this? Any hints? What could be starting to fail?
Paul
Paul
From experience the most likely cause is due to the brake light switch or if 2 brake light bulbs are blown. Check the bulbs first and replace if nessacery, then have a 5051 check run on the vehicle which will show up any faults. There can be a fault with the switch even if the brake lights work as the switch also sends a signal to the engine control unit. The rod on the switch may also be incorrectly adjusted causing an implausable signal due to, to much pressure being applied to the brake pedal before the lights come on.
Hope this has been helpful to you
Very easy to do. They just pull off... Just need to remove each wheel.... If there is one/two with a considerable amount of build up clean them (they are just magnets and just need to be pulled off) then keep driving and see if the alarm comes back.
Have you tried removing all the ABS sensors and checking that they are not built up with metal shavings. This will cause the computer to give a false alarm.
Hope this is will resolve your problem. Otherwise i would check that it is the connection to the abs module (apparently a common problem) which may just need to unplugged and plugged back due to a bad connection, or faulty sensor/s.
gertron30
Feb 1, 2010 06:34 PM
