Alternator output specs
Old May 1, 2011 | 03:42 AM
NZ-S-IV's Avatar
Default Alternator output specs
Hi all,
I have been chasing a random electrical problem on my B5 S4 for the past 6 months.
Finally got a VAG-COM and connected it up to find that the 'battery voltage' would drop as low as 12.8 while the car is running.
It has so far killed a battery, and caused the ECU to 'lose some code' and had to be reflashed.
I was wondering (because I cant find in the service manual) what the rated output of the alternator should be...in my experience, 13.7-14.1v is standard output for most alternators. For the duration of the logging I did today, it did not go above 13.4 volts - too low in my opinion.
Cheers,
Andrew
Old May 1, 2011 | 08:12 AM
Huey52's Avatar
Concur, with the engine running and applying a voltmeter across the battery terminals you should be reading ~14VDC. Any lower is suspect - degraded alternator windings/bushes, loose belt, loose connections, degraded wiring, etc.
Originally Posted by NZ-S-IV
Hi all,
Cheers,
Andrew
Black Rat
Apr 29, 2011 09:45 AM
trill
Jun 27, 2009 12:49 AM
Threeputt
May 22, 2008 08:55 AM
gilee_8
Nov 28, 2005 02:17 AM
