audi fuel/air problem!
Old 04-13-2006, 02:39 AM
si937's Avatar
Default audi fuel/air problem!
Hey guys.Im a newbe here. just got a 02 audi TT (180hp). I have a check engine light, so i took it to autozone to have it checked and they had told me it was something to do with my air/fuel. thats all they said. I would take it to a dealer but the nearest dealer is 3 hours away. Now what my car is doing is stumbling when i am on the gas. It picks up then slows down, then picks up. if anyone has had a problem similar to this i would appreciate any advice. I am thinking maybe o2 sensor or Mass Air Flow sensor but not sure. thanks for any help!
Old 04-13-2006, 03:12 AM
Beer Mod's Avatar
Default RE: audi fuel/air problem!
Could be alot of stuff MAF maybe......Need a shop that has VAG that will tell you in 2 min exactly whats up.....Find any close VW/Audi/Porsche shop
Old 04-13-2006, 06:13 AM
rich1068's Avatar
Yep. Sounds like MAF or Lambda sensor. As Beer Mod says you need VAG COM.
Old 04-13-2006, 01:52 PM
CRAZYHAWK's Avatar
Could be a vacuum leak. Do a search for Steve-Hall Vag-Com.
Old 04-13-2006, 04:38 PM
si937's Avatar
Thanks guys for the info. i took it back to autozone and they had told me that i am missfiring in all 4 cylinders and need a new 02 sensor. Would a 02sensor cause the misfiring or is misfiring another problem? thanks
Old 04-13-2006, 04:58 PM
rich1068's Avatar
ORIGINAL: si937
By O2 sensor I'm guessing at the lamda sensor (sorry, me no speak American ) and yes it would. But so would the MAF. At least we can rule out coil packs unless you're very unlucky.
Speaking of coil packs, it's thanks to all the American VAG owners that we got our problems sorted. If you guys hadn't shouted so loudly we would have been still taking our cars to dealers with mysterious 'I've never heard of that before Sir' problems. Funnily enough though I have noted on UK based forums an increase in coil pack related queries. Looks like the L's are giving up the ghost too...
Old 04-13-2006, 06:49 PM
AWDaholic's Avatar
Senior Administrator
Yes, Lambda sensor = O2 sensor...
Old 04-13-2006, 07:23 PM
Default RE: Audi fuel/air problem!
random/multiple cylinder(s) - misfire detected, check spark plugs/plug leads/injectors/ignition coil pack/low cylinder compression/wiring ( code 16684 )
Old 04-13-2006, 08:20 PM
si937's Avatar
codes are p1128 and p0300 (1,2,3,4 cylinders. MAF sensor maybe?
Old 04-14-2006, 07:39 AM
p1128 long term fuel trim bank 1 too lean, intake/exhaust leak, AIR system- hose leak.
P0300 random/multiple cylinder(s) - misfire detected, check spark plugs/plug leads/injectors/ignition coil pack/low cylinder compression/wiring ( code 16684 )
you could have air getting in by the injectors "bad seals" and do a compression test, its not the MAF that's doing its job
vlady
02-12-2014 07:15 AM
lukacio
12-13-2008 07:57 AM
fastazs4
11-24-2008 05:36 PM
bazza_200
11-29-2007 07:29 AM
sdiegidio
04-07-2007 10:28 AM
Quick Reply: audi fuel/air problem!
