Bad news... might have killed my car. newb needs help! please give input!!!
Old Dec 5, 2006 | 04:02 PM
reedodafreedo's Avatar
Default Bad news... might have killed my car. newb needs help! please give input!!!
so just bought an a4 about a week ago.. 97 1.8t quattro 90xxx miles.
So i had the timing belt and water pump replaced and they also did a couple other belts along with changing the oil and oil filter. a couple days later, the oil light came on.
me being a dumbass, didnt think much of it, checked the oil and it looked fine, i just figured i would take it to a jiify lube in the next day or two when i got around to it.
so i wait a few days, and when i start her up a clicking noise occured from the engine bay area. didnt sound too serious and i didnt think much of and just figured i would take it to the jiffy after work, so after work i start her up again and the clicking is a bit louder and doesnt go away this time. as i accelerate more, it got louder. then i shift into second and it gets louder and a loud clanking and bunch of chaotic noises. i shut her off. start up again and the same terrible loud expensive clanking noise.
i am now thinking maybe i didnt have sufficient oil pressure.... i realize how much of a dumbass i am. please let me know what you would guess the diagnosis is and how much i am looking at.... thanks and prey for me and my baby.
Old Dec 5, 2006 | 04:10 PM
techbod's Avatar
Default RE: Bad news... please give input!!!
im guessing the oil pump has failed hence the clicking which is the hydraulic lifters getting no oil
Old Dec 5, 2006 | 04:17 PM
so you dont think it was anything serious internally? what happens when the lifters dont get enough oil?
say that was the case... i replace the oil pump... what else would have to be done? i am trying to get a feel for how much money i am going to have to throw at this.
Old Dec 5, 2006 | 04:48 PM
GeilKyle2's Avatar
they just changed the oil pump? It sounds like somebody didn't do something right when they changed it
Old Dec 5, 2006 | 05:12 PM
idice's Avatar
I have an 2000 A4 before i got this one i had a Toyota Paseo. I had the same problem with the car and that pushed me to buy a new one. I took it in and i took the oil pan off. Because there was not enaph oil pressure the oil did not lubricate the pistons and new pistons had to be put in. Don`t drive it. You will mess it up more. Take it and pay the 95$ an hour for audi to look at it. Most likely you will need a new camshaft and new piston bearings, posable new pistons. I hope im wrong but good luck.
Old Dec 5, 2006 | 05:13 PM
no, sorry. they did not change the oil pump, but just the standard filter swap with an oil change.
Old Dec 6, 2006 | 12:46 AM
dankhound's Avatar
It sounds like a plugged up oil pickup due to sludge. Search for sludge and you should find a bunch of threads. Most likely the noise you hear is the camshaft chain tensioner making noise due to lack of lubrication.
Old Dec 6, 2006 | 12:59 AM
well good news, $4700 and about a week from now, i will be getting my car back with a new engine:/.....
i suggest everybody listens to their car when it talks to you.
Old Dec 6, 2006 | 10:31 AM
idice's Avatar
Dam sorry to hear. As my post above i was pretty close with the results. Thats y is good to change your oil often. If you took it to a lube stop you should sue the place since they are the ones that cause this problem. Go to audi ask them for a fault report and y did this happened take yoru receipt from the lube stop and ask your lawyer you might have a new engine for free. Good luck.
jss
Nov 9, 2008 02:04 PM
NuYorka103185
Apr 15, 2007 03:03 AM
bmwtoaudi
Jan 31, 2007 03:51 PM
thndrlight
May 5, 2005 10:43 PM
