changing to different size rims
Old May 5, 2008 | 03:36 PM
02audia41.8's Avatar
Default changing to different size rims
so my dad has an extra set of hre performance rims that are 19s but i know they dont fit because the bolts dont fit on my axle because theyre alot bigger cause they were originally on his porsche but the fronts are 235/35 zr 19 and rears are 315/25 zr 19 and i was wondering if i would just have to replace what the nuts go into or would i have to do other stuff for them to fit and an estimated price if youknow
Old May 5, 2008 | 06:14 PM
Default RE: changing to different size rims
bump
Old May 5, 2008 | 11:43 PM
ImTheDevil's Avatar
They're not gonna fit. The offset/bolt pattern/bolt spacing either for sure are different, or are likely to be different. You'll have to buy wheels meant for the Audi. If they're a multipiece wheel, you could probably order new center sections for them, and then bolt them to the rims, so you could use them. But if you did, despite spending huge money, you'd then have to worry about fitting 11-12" wide wheels under the rear of the car, and the Audi simply isn't going to have that kind of room without at least rolling fenderlips, and probably flaring them as well.
Sell those wheels, and use the money to buy a set for your car.
SnowBlindYooper
Mar 9, 2015 11:16 AM
zaboomafoo1212
Jun 27, 2012 12:18 PM
dougberg
Aug 28, 2008 03:50 PM
WaterGuy
May 13, 2006 11:24 AM
