CV joint problem
My 98 A4 has a bad cv joint on the front passanger side. If I grab the shaft, I can move it all over the place, so i know it's bad. The strange thing is that the car will not move at all. The engine runs good with no lights or codes when in park or netural. If i shift to drive or reverse there is a loud grinding noise coming from the engine bay in the cv shaft area. With that front wheel jacked up i can rotate it with lots of grinding. My question is can a competely blown cv joint cause the car not to drive the other 3 wheels?
yep, i you loose one wheel on a quattro your not going anywhere. best just replace the whole axle, its actually cheaper than replacing the joint. make sure you use new bolts. a few of us had our new axles fall off.
