DIY IC question
if you dont have a MAP sensor then you do have a MAF sensor, you could fit a resistor in its place but not recommended because it burns the valves out
all it does is tell the ECU the air temp is perfect all the time ( fixed signal )so under cold start the system dosnt function
akitamike
Jun 9, 2008 11:05 AM
SouthernAudi
Oct 14, 2007 06:47 PM
