DIY IC question
Old Feb 22, 2007 | 08:38 PM
MissionCtrl's Avatar
Default DIY IC question
Just a quick question,
if anyone has done this, what did you do with the thrust sensor???
Old Feb 23, 2007 | 03:11 PM
2k S4's Avatar
Default RE: DIY IC question
What's the thrust sensor?
Old Feb 23, 2007 | 03:47 PM
thrust sensor/map sensor. turns out i don't have one. yay for me
Old Feb 23, 2007 | 03:54 PM
techbod's Avatar
if you dont have a MAP sensor then you do have a MAF sensor, you could fit a resistor in its place but not recommended because it burns the valves out
all it does is tell the ECU the air temp is perfect all the time ( fixed signal )so under cold start the system dosnt function
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
