heat prob 1996 a4 6cyl
ok i have flushed out core hose with air and water and bled system but what i have found that the coolant is not running steady into the core it is spitting when i bled the system the coolant was come out the pin hole on left hose but when i gave it gas the cooolant stop coming out of the bleeder hole also i get no temp gauge reading no matter how long i run the car gauge work before was saying it was running hot so took mechanic he change the sensor took back now he says gauge im a little wary of that since it worked before sensor and i been going at with him about the heat because it worked before i had timing belt put in water pump thermo now im wondering if the thermostat is stuck open or if water pump faulty he says no claims heater core but since i flushed it out i get heat when i run down the road but not when i idle and the spitting of the coolant leaves to believe somthing not pumping right anyhelp would be appreciated ty tony
