i am so stuck at this point and so close
Old Jun 25, 2006 | 12:12 AM
drageron's Avatar
Default i am so stuck at this point and so close
heres the deal
1. bought a 02 1.8t wrecked in the front
2. no keys---damn
3. rebuilt everything- urethane kit, carbon hood,
4. airbags did blow
5. just got back from dealer - flatbedded my quattro to have the new keys matched to the immobilizer
6. almost tuurns over but dont want to catch- left plugs out and i get continuous spark but maybe the fuel stops??
7. vag-com and i pulled some codes--- boost pressure valve no signal
anyway here they are
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 63351
1 Fault Found:
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 004 - No Signal/Communication
Readiness: 0110 1101
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC
Controller: 8E0 820 043 G
Component: A4 Klimaautomat 1012
Coding: 00000
Shop #: WSC 63351
No fault code found.
Address 09: Cent. Elect.
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
4 Faults Found:
01494 - Bulb for Parking Lamps: Left (M1)
57-00 - Electric Circuit Failure
01498 - Bulb for Parking Lamps: Right (M3)
01496 - Bulb for Fog-Lamps: Left (L22)
01500 - Bulb for Fog-Lamps: Right (L23)
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 L
Component: Lenks?ulenmodul 0308
Coding: 00041
Shop #: WSC 63351
2 Faults Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
Address 17: Instruments
Controller: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 03200
Shop #: WSC 01312
WAULC68E22A269246 AUZ6Z0B0053942
Address 45: Inter. Monitor
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
81-00 - Open
Address 46: Central Conv.
Controller: 8E0 959 433 T
Component: Komfortger?t T5B 0619
Coding: 11788
Shop #: WSC 63351
11 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
52-10 - Supply Voltage Too High - Intermittent
01134 - Alarm Horn (H12)
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01331 - Door Control Module: Driver Side (J386)
01332 - Door Control Module: Passenger Side (J387)
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
Address 56: Radio
Controller: 8E0 035 195 A
Component: symphony II NP2 0050
Coding: 00001
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
Why cant i get her to turn over to start it seems so close????
could vaccum be a no start issue
could it be my fuel pump
could it be my the boost pressur valve sensor thing
i love my audi anybody have an idea
also, i have no manual
anybody know what the key in the car signal is on the dashboard, it does go off after a sec
also whats the epc light mean
and finnally whats the light with the triangle and half circle around it
thanks guys
fredct
Jun 16, 2015 10:57 AM
Trigger200
B7 Models
Apr 27, 2015 11:58 PM
audiS4jls
Apr 10, 2009 12:15 AM
fibersnet
Aug 3, 2007 11:50 PM
