Need info regarding Oil Change
Old 09-12-2006, 08:37 PM
prashantsp's Avatar
Default Need info regarding Oil Change
Hi,
I bought an Audi A6 2002 3.0 Quattro in March of this year. When I bought the car from the dealer, I was not given information about the next oil change / service etc..
I would really appreciate if someone could give me info regarding the recommended oil change (eg. every 5000 miles or every 6 months etc..).
Thanks,
Prashanth
Old 09-12-2006, 09:09 PM
CRAZYHAWK's Avatar
Default RE: Need info regarding Oil Change
Oil is changed every 10K mi. with synthetic oil.
Go to for intervals
www.bentleypublishers.com
Old 09-12-2006, 09:17 PM
CRAZYHAWK's Avatar
https://www.audiforums.com/m_16044/m...l/tm.htm#16044
Old 09-13-2006, 07:24 AM
wonka's Avatar
It is recommended that you check or do change oil every 5000 miles. Just be careful about those aftermarket oil additives that many are inclined to use.
Old 09-13-2006, 05:32 PM
CRAZYHAWK's Avatar
wonka, it is 10K mi.
http://www.bentleypublishers.com/ima...ance.sched.pdf
Old 09-13-2006, 06:21 PM
a6xlr8s's Avatar
It is 10k uder normal driving conditions only if using fully synthetic oil such as mobil 1 and a 10k approved oil filter wich is not the standard oem filter. If you are an aggresive driver I would up the intervals to 5k with mobil 1. I tend to get 180,000 to 240,000 miles out of my cars with this method. The oil change service message is set on a 3k oil change unless it has been changed via obc/computer to a different interval some are at 5k mi or 7.5k (you need to watch it the fist time). If you need to reset it in-between changes the directions are in the stadard manual and are very easy to follow.
Old 09-13-2006, 09:22 PM
CRAZYHAWK's Avatar
Mine comes on around 8.2K mi. The dealer used mineral ,dyno, oil for the first 50K mi.
I have 110K mi. now with the engine running fine. I've been using Mobil 1 0W-40 since 70K mi.
Old 09-14-2006, 10:19 PM
robfresh's Avatar
Will your check engine light come on if you need an oil change?
Old 09-15-2006, 12:48 AM
a6xlr8s's Avatar
your check engine light should not come on if you need an oil change! The trip counter will indicate oil change when you start the car for several seconds or until you shift the car.
Bagheera223
S4
03-17-2015 11:10 AM
mmdambro
12-16-2010 12:23 PM
bjp1
04-26-2010 09:49 AM
jjuzwik
11-16-2007 06:37 PM
Dr_Vitez
02-15-2005 10:07 PM
Quick Reply: Need info regarding Oil Change
