noise from brakes after axle replace
Old Feb 25, 2012 | 09:41 PM
biocpu's Avatar
Default noise from brakes after axle replace
Just replaced the left front axle with EMPI OEM, and reinstalled the right front axle (with the original axle; outer CV boot got replaced).
When the car is moving (~30mph and up) I am hearing the constant noise from both brakes. I think the noise comes from the friction between the pad and the disc. The disc/pad on either side is brand new (<50 miles on). Before replacing the axles, there was no noise even with the new disc/pad. Becomes noisier when turning. Having said so, the noise is not loud... but I can hear.
Any clue how the noise developed (eg, too tight or loose axle bolt - I followed Bentley book: 133ftlb + 180deg)?
Should I do anything? Or should I let time resolve this (the pad and disc wear out)?
Thanks,
Old Feb 26, 2012 | 04:37 AM
mmagha55's Avatar
it could be the plate behind the rotor ,move it back by screw driver.
Old Feb 26, 2012 | 07:06 AM
M5S5's Avatar
Tech Certified
Agreed with above , the backing plates probably got bent from trying to move steering by grabbing the rotor & backing plate.
Old Feb 26, 2012 | 11:43 AM
Brityank's Avatar
I had this happen on my Ford explorer when I changed the bearing hubs so I also agree.
Old Feb 26, 2012 | 12:21 PM
ImTheDevil's Avatar
Agreed. If you didn't do so during reassembly, I would also pull the caliper sliders back out and wire-brush them, then coat them with a high-temp ceramic grease. Audi sliders are known to bind up and seize the calipers.
Old Feb 26, 2012 | 10:51 PM
biocpu's Avatar
Thanks guys. That was it! I didn't even have to take the wheel off.
Old Aug 10, 2012 | 03:18 PM
trshman6's Avatar
haha, just did my axle, same thing, must have mashed that shroud against back of rotor, wasted a fresh pair of rubber gloves on half a second fix. Love AudiForums!!!
KoolMan
Feb 27, 2013 11:37 PM
Shermdawg
Oct 26, 2012 02:11 PM
biocpu
Feb 13, 2012 04:28 PM
sa9023
Dec 21, 2010 07:41 PM
paulywalnuts446
Sep 29, 2009 11:10 AM
