noise from brakes after axle replace
Just replaced the left front axle with EMPI OEM, and reinstalled the right front axle (with the original axle; outer CV boot got replaced).
When the car is moving (~30mph and up) I am hearing the constant noise from both brakes. I think the noise comes from the friction between the pad and the disc. The disc/pad on either side is brand new (<50 miles on). Before replacing the axles, there was no noise even with the new disc/pad. Becomes noisier when turning. Having said so, the noise is not loud... but I can hear.
Any clue how the noise developed (eg, too tight or loose axle bolt - I followed Bentley book: 133ftlb + 180deg)?
Should I do anything? Or should I let time resolve this (the pad and disc wear out)?
Thanks,
Thanks,
Agreed. If you didn't do so during reassembly, I would also pull the caliper sliders back out and wire-brush them, then coat them with a high-temp ceramic grease. Audi sliders are known to bind up and seize the calipers.
paulywalnuts446
Sep 29, 2009 11:10 AM
