noise from head unit, loose wire or speaker ????
Old Apr 22, 2008 | 03:12 PM
shaba's Avatar
Default noise from head unit, loose wire or speaker ????
New to the forum and have a problem I can't seem to correct.
I have a 99 A6 Avant wagon with the Bose System. Thesound isfine until I hita bump and then I will get a noise that goes away if I tap(hit) the center console. Could this be the head unit or a loose connection of some kind? It only comes from the front right hand side and really doesn't seem to be the speaker but..... Has anyone else had this problem? Remedies? Thanks for the help.
Old Apr 26, 2008 | 11:49 AM
AudiTech616's Avatar
Default RE: noise from head unit, loose wire or speaker ????
You probably have some loose clips. Check the panel on the passenger side by the glove compartment. I say take out the panel and drive without it for a while and see what happens. Just a suggestion since I'm not there to here the noise. Good luck
96quattro2.8
Mar 21, 2013 02:07 PM
ooTToo
Sep 25, 2008 09:20 PM
Fussbett
Oct 12, 2007 06:19 PM
kevinpunzalan
Aug 25, 2006 10:47 AM
gazzaman28
Dec 5, 2004 11:16 AM
