Part no 058103221 Vent hose
Old Jun 16, 2017 | 01:59 PM
94heathfield's Avatar
Default Part no 058103221 Vent hose
Can anyone advise where I can get a replacement 058103221 Vent hose for 1999 V reg A4?
Stopped making 01/10/2016, without replacement
Old Jun 16, 2017 | 08:40 PM
dave944's Avatar
Any of these look like the part you need? audi 058103221 | eBay
Old Dec 2, 2020 | 01:59 AM
marteA4's Avatar
That's the part I need for my ADR & APT engines, it's for the 'Non Turbo' 1.8 motors.
Unfortunately I ordered (4x) 058103221E , which is a different hose that does the same job, on a Turbo version...
So make sure you order the 058103221H version. I see it can be ordered from Poland cheaply. Considering you could order a few & sell them on.
The USA market dosn't use the 1.8 nonturbo version so it's sorta hard to get anywhere but in Europe. & Expensive elsewhere.
I did adapt a hose & used a 90° pipe bend, but I'd rather have the original hose.
Take into account that there should be a rubber diaphragm one way valve in the plastic inlet ducting it's attached to.
And at the other end, the plastic gooseneck will need to be replaced & the housing it fits into will be needed to be cleaned.
It's easier to just unscrews the cap screws & remove this whole unit, than to remove the gooseneck fitting itself.
I'm wondering if I should go for the Turbo version rocker cover. That way instead of crankcase ventilation being just 'Suck + blow' from the crankcase. I could have ' Suck' at the crankcase & 'Blow' at the camshaft cover. Giving it airflow thru the engine.
Lynskey
May 14, 2013 04:07 PM
MattSCESC
Mar 5, 2012 11:53 PM
gDmM@NnY
Nov 15, 2010 03:18 PM
wings7351
Apr 9, 2007 06:49 PM
modset
Feb 26, 2007 12:47 AM
