Passat to AUDI ECU Swap
Old Dec 14, 2011 | 10:44 PM
Goingallout's Avatar
Default Passat to AUDI ECU Swap
Just wondering if anyone knew if a 2002 Passat ECU would work in my 2001 AUdi A4.... Same engines transmission...
Thanks
Old Dec 15, 2011 | 06:18 AM
02A6Beau's Avatar
I think....
as long as the numbers on the ECU match it will work but....
I dunno for sure
Old Dec 17, 2011 | 07:25 PM
ImTheDevil's Avatar
Matching numbers mean it should work - that's very likely the only way it will though. Curious why you want to do this...?
Old Dec 22, 2011 | 02:26 AM
I fould a GIAC Chipped ECU out of a 2001 Passat!! cheap!!
Old Dec 22, 2011 | 11:35 PM
EuroCustoms's Avatar
Former Sponsor
Thanks
As long as the ECU part number matches it should be ok the only problem you might have is defeating the immobilizer. You will know if it doesn't start. The dealership (expensive side) or a majority of tuners out there can defeat that. If you have any issues with it we can defeat it you would have to send me your ECU. If that's the case send me a pm and I'll work in an AudiForums discount for you.
Old Jan 11, 2012 | 05:02 PM
Hey so I did the swap!! And car runs perfect except for the ESP and ABS lights are on! Is this something that can be resolved with a vag-com? And gotta say huge difference from stock! Finally fun to drive!
65Ford
Sep 4, 2014 11:26 PM
scout78
Mar 8, 2010 03:18 PM
mccutch2u
Apr 3, 2008 04:22 PM
diego7
Dec 18, 2007 10:13 PM
