Programing imobilizer in key
Old Jul 22, 2005 | 05:44 PM
ebolla13's Avatar
Default Programing imobilizer in key
-Yes I have done a search in the forums-
I'm trying to figure out how to program the immobilizer chip in my key for my '02 A4
I have tried leaving a key turned in the ignition and then locking the car from outside with the new key but so far that has not worked
Is there another method?
Or what may I be doing wrong?
The dealership has told me that programing the imobilizer is $30
I'd perfer to do it myself
Thanks for the help.
Old Jul 22, 2005 | 07:24 PM
BaconBait's Avatar
Default RE: Programing imobilizer in key
https://www.audiforums.com/m_44208/m...m/tm.htm#44208
You may have to clear the memory first.
Remote transmitter coding procedure
- Switch ignition on (using separate key).
- Lock vehicle from outside using key to be coded via driver-side door lock.
- Press "unlock" button within 5 seconds often enough to reach next
memory position (in example given, twice). Every time you hit the button
it goes to a different memory position. So if you hit it twice for the first key
and the second key, the first key will no longer work.
- Every press of the button is confirmed by the emergency flashers and
the anti-theft system horn.
- Wait 5 seconds.
- Now press "unlock" button one more time (vehicle unlocks).
- Switch ignition off and remove ignition key.
- Check function of new transmitter.
Notes:
Be sure that new transmitters are always coded into free memory
positions. If occupied positions (distinguishable by a "1") are used,
the transmitter previously coded to this position will no longer work.
Existing remote transmitter recoding procedure
- Press any button on transmitter.
If vehicle does not respond by locking or unlocking:
- Lock and unlock vehicle within 30 seconds using driver-side lock.
- Now check function of recoded remote transmitter.
Clearing memory positions
Notes:
It is possible to clear all memory positions, e.g. if a customer loses
a remote transmitter. Proceed as follows:
- Switch ignition on using key.
- Then mechanically lock central locking from outside vehicle using key.
- Activate remote transmitter "unlock" button on key five times at one
second intervals. A short horn signal will sound each time.
- Then, after 6 seconds, press remote transmitter "unlock" button to
confirm this clearing procedure one more time.
- Central locking should no longer unlock itself via remote transmitter.
- Switch ignition off.
Up to four transmitters can now be coded again.
Old Jul 22, 2005 | 09:48 PM
ebolla13's Avatar
Thanks for the fast reply-
I think it must be an issue with the remote cuz i'm not getting and feedback from the buttons
i will have to check the batteries
Hey has anyone on the forum thought to make a FAQ section where neebies like me can easily find answers to these types of questions?
I know that lots of questions are asked about things like Keys and Chip-ing
They are asked so much that a search through the forums can take hours and still not find all the posts
just an idea...
thanks again
kafka
Apr 23, 2014 02:35 PM
tse07
Feb 25, 2008 04:35 PM
SMITHWICKS440
Jan 9, 2008 12:22 AM
Soley4pres
Apr 24, 2007 09:46 PM
sg33
Oct 11, 2006 02:44 AM
