squeaky steering wheel
Old Nov 10, 2005 | 01:00 PM
a6avant's Avatar
Default squeaky steering wheel
my steering wheel squeaks when I turn the wheel. It is not power steering fluid or anything. It is coming from just behind the wheel. kind of a high pitch rubber on rubber kinda squeak. I am just going to spray wd-40 in the seams. I'm kidding, sorta.
Old Nov 10, 2005 | 06:50 PM
dankhound's Avatar
Default RE: squeaky steering wheel
If the steering wheel isnt rubbing on the plastic trim, youll need a new clockspring. Otherwise your steering column has probably collapsed and youll need to replace the whole steering column.
Old Nov 10, 2005 | 07:13 PM
techbod's Avatar
clock spring???? only if airbag light is on, steering column has probably collapsed "if its had an accident", chances are its catching/rubbing against other plastics
Old Nov 10, 2005 | 09:33 PM
a6avant's Avatar
it has not been in a accident and the light isn't on. I kinda think it is just rubber and plastic rubbin. I'm thinking about taking off the plastic around the column and trying to decifer it that way. While trying not to ruin the whole thing.
Old Nov 10, 2005 | 09:51 PM
techbod's Avatar
wd40 is a good idea or silicon spray, there is a bushing 2 thirds the way down the column near the peddles ensure it in all the way the steering wheel/column has excess movement if it isn't
Old Nov 20, 2005 | 01:29 AM
beefski's Avatar
have you tried changing the positions of the tilt & telescoping?
Old Nov 20, 2005 | 01:03 PM
techbod's Avatar
have you tried changing the positions of the tilt & telescoping? very good idea
other places to check follow the red lines
[IMG]local://upfiles/12092/F749C32991E748D88F4C07493CCB5170.gif[/IMG]
Old Nov 24, 2005 | 01:00 AM
sir_daft's Avatar
My car was doing the SAME thing, and I tok apart the entire steering colum assembly. It was actually one of the ball joints (look at that pic and it's where the far left red line pointed to). I soaked it in oil and it fixed it. That was about 4 mos ago. Just recently it started squeaking again. Not sure what the dealio is though?? I dont feel like taking it apart AGAIN.
JustWondering
B7 Models
Sep 11, 2011 11:17 AM
Skythe
Sep 28, 2010 11:56 PM
spcmky
Aug 30, 2010 01:16 PM
Audi S4 Turbo
Apr 22, 2010 10:42 PM
keepupp
Aug 21, 2006 07:56 PM
