Vibrates when accelerating
Old Apr 20, 2006 | 09:44 PM
mlev's Avatar
Default Vibrates when accelerating
I have a 2003 A4 3.0 and it has recently started to shake when I accelerate. It will stop as soon as I take my foot off the gas. Audi has cleaned out the transmission and the fuel intake. 500 bucks and no fix. Any ideas?
Old Apr 20, 2006 | 10:11 PM
A4PLAYIN's Avatar
Default RE: Vibrates when accelerating
check your fuel pump.... theirs an audi recall on it.... its worth a shot, mine hums but they don't want to cover it at the dealer... said its mostly on the 3.0s not the 1.8s...... those bastards.[:'(]
Old Apr 21, 2006 | 03:03 PM
beefski's Avatar
could be a motor or trany mount
Old Apr 28, 2006 | 07:06 PM
mlev's Avatar
Update----Audi just told me it was the left drive shaft axle. I hope they have it right this time. I am picking up today.
Old May 14, 2006 | 04:41 AM
brice32's Avatar
mlev - I sent you a message on this one. How did it turn out. Sounds (feels) like I have the same problem on my 2002 A4 3.0. Thanks.
Old May 14, 2006 | 05:32 PM
mlev's Avatar
It ended up being a cracked or broken drivers side axle drive shaft. Not sure exactly the name, but it had those words in the problem. It cost around 900 bucks, but the car is fine now.
Old May 25, 2006 | 08:23 PM
brice32's Avatar
Thanks for the reply. I tried to save a little $$ and take it to a non dealer mechanic. They did find a nice dent in the center of my alloy front left. They went on to say they inspected the axles and didn't find a problem. Still has the same problem after replacing rim and I am fairly sure it's the problem you describe. Helps to go to the dealer with a little info. Thanks.
Old May 25, 2006 | 10:55 PM
flyboy's Avatar
a cracked axel shaft. that doesn't just happen. I mean its a piece of steel. I would look into getting that paid for. Call the news and see if they will help you. also 900 bucks is a hella expensive fix for that, To put it in perspective. I just bought two, yes two new axels for less than 250. Just conserned that your getting screwed.
sztywny
B7 Models
Aug 26, 2014 10:24 AM
kakashisan
Mar 30, 2008 07:11 PM
kakashisan
Jan 16, 2008 05:22 PM
jonsaudi
Nov 20, 2007 01:39 PM
ram
Apr 24, 2006 05:59 PM
