WINDOWS HAVING TOUBLE GOING UP
Old Sep 2, 2007 | 01:18 PM
jessiec132's Avatar
Default WINDOWS HAVING TOUBLE GOING UP
i have a 2001 audi a6 2.7t and i having trouble with my windows going up and i need to help them going up pushing them with my hands.the dealer we bought it from said they just need silicone to go up i was wondering if that is true or do i need to replace the motors or something else?thankyou
Old Sep 2, 2007 | 02:28 PM
auditech79's Avatar
Default RE: WINDOWS HAVING TOUBLE GOING UP
If its the front windows there are usually plastic clips that pull the window up and down, they eventually crack and make it hard for the window travel, eventually won't lift at all.
I would always keep the slides lubricated with silicone but chances are the clips are going bad.
You can buy just the clips instead of buying the entire window regulator which saves you major $$$$
Old Sep 2, 2007 | 03:49 PM
jessiec132's Avatar
the clips where can i get them andhow much are they? alsowhere do i install them do i have to take the door panel apart or they just clip on the window simple as that
Old Sep 2, 2007 | 04:19 PM
auditech79's Avatar
You get them at the dealer, not sure how much they cost exactly but i think they are in the $50 range for a pair.
You have to pull the door panel off which is dirt easy, there are two small phillips screw at the ends of the top of the panel, take those out then pull the panel straight upwards. Roll the window all the way up and you should be able to get the clips off the regulator cable, i think there is a small torx bolt holding it on from behind it which can be a little pain to get at.
Old Sep 3, 2007 | 11:19 AM
2k S4's Avatar
You are one of the first people who the Dealer wants to do a lower service, & YOU want to get the whole thing done.
I would have found out how much they are going to charge, & just have them do it, if it's cheap.
Old Sep 5, 2007 | 04:20 AM
JETSPEED333's Avatar
SoCal Crew Member
this may actually becaused by window glass channel dimensions out of tolerance (too narrow).
you may need to repair the channel tolerance by widening the channel...
there is even aspecial Tool No: JC4300for the job.
halfpint
Jul 28, 2010 03:25 PM
Audacity
Jul 22, 2010 09:25 PM
striker451
Sep 4, 2009 03:44 PM
jduplooy
Jul 8, 2007 10:18 PM
CamoA6
Nov 8, 2006 02:09 AM
