Wont start!! No Spark! HELP!
Old Jan 15, 2006 | 11:44 PM
ursmokd's Avatar
Default Wont start!! No Spark! HELP!
Ok so im driving down the road, and all of a sudden my car bogs doen and sounds like a subaru.. check engine light is flashing. I check plugs, wires, yadda yadda, but still no go.. its only running on 2 cylinders. Then the Engine Timing fuse blows and wont start. I replace the fuse and it starts up, again sounding like a Subaru. No spark to the front 2 cylinders which are I believe 1, and 3. What do I do??? Anyone have this problem? Please help!!
Old Jan 18, 2006 | 07:24 AM
Karl's Avatar
Default RE: Wont start!! No Spark! HELP!
Pull codes with a scanner and let us know what you get
Old Jan 18, 2006 | 11:49 AM
mastvadz71's Avatar
Member
what year ,what engine do yo u have
Old Dec 2, 2007 | 09:13 AM
Honda882000's Avatar
I have a A4 1.8T which had the same issue a few months back. Ended up being the ignition control module. You might have the same problem.
Old Dec 2, 2007 | 04:39 PM
KevinV10's Avatar
couple quick checks.. depending on your ignition system... try swapping the coils for the cylinders that work with the ones that dont, see if the problem follows the coils.. i wouldnt run it anymore than it has to be though.. blinking mil light means imminent damge can occur. its not just a warning flash, its a shut me off now flash...
keith2580
Mar 24, 2013 03:09 PM
Dylan Cure
Sep 4, 2012 04:21 AM
Billydakid
Oct 29, 2010 02:40 AM
goc305
Apr 27, 2007 07:41 PM
