Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Diy fmic
Old Feb 20, 2010 | 09:18 AM
vtraudt's Avatar
Default Diy fmic
Looking at the intake pipe running under the bumper in front of the engine, and the astronomical (including corresponding mark-up) price of the offered FMIC kits ($1,000 for an intercooler, 4 bent pipes, 8 flex connectors and a bunch of hose clamps), I am wondering:
Just take this pipe out (hose clamp on passenger and driver side), cut and splice a small intercooler in IN ADDITION to the factory intercooler?
Cost: $100 plus some elbow grease.
A full DIY with replacing the factory IC requires some custom tube bending and fit fiddling.
I'm sure no-one has done that, but looking for comments:
- flow: will the larger internal cross section of the intercooler (compared to a straigt pipe (my guess: the insided diamter of the current pipe is 1.75 inch?) add further flow restrictions?
- intercooler area: well, obvious at least twice as much
- 'heat sink': the additional thermal mass will act as an additional heat sink, which IMO can be good an bad: it can quickly take out heat for short periods of high boost (= high temperature), but will also give back heat for no boost periods.
Your thoughts?
Old Feb 20, 2010 | 10:52 PM
FASTER's Avatar
Tech Slut
I think it will create a noticeable pressure drop and extra lag because of the added volume and 2 IC cores... i also think its overall just a dumb idea no offense lol. Your k03 wont like it, and according to your sig you are only running 12.5psi which is pretty low for a chipped 1.8t. scrap the idea and buy an ebay fmic kit.
Old Feb 21, 2010 | 09:12 AM
vtraudt's Avatar
What is the recommended (no more than 300 hp peak)
- intercooler size
- connecting pipe diameter
(obviously: compromise between "bigger the better" = increased lag and larger heat sink mass, but lower flow restriction vs. "smaller is better" = less lag, less heat sink, higher flow restrictions).
I remember seeing somewhere that 2" is good, 2.25" is plenty and everything above just adds lag?
Old Feb 22, 2010 | 10:17 PM
FASTER's Avatar
Tech Slut
one of the small ebay cores with like 2" piping is more than enough for a k04. But if you plan on going BT in the future then i would just spend the money on a real (big) fmic.
Old Feb 23, 2010 | 07:52 AM
vtraudt's Avatar
Anyone know what the OEM sizes/dimension are for
- the intercooler
- the connecting pipes
Old Mar 30, 2010 | 07:13 AM
joenelson7687's Avatar
The intercooler pipes are 2 inch. Don't do that set up. I did my FMIC for 120 (ebay and craigslist baby!). Look in the DIY section for FMIC write up...
Old Mar 30, 2010 | 08:17 AM
vtraudt's Avatar
I used the DIY FMIC write up as a decision tool to
- not attempt to do the bends from scratch
- use ebay 'custom' kit for 300 incl 20x6x2.75 plus 2" pipe
I I had to do it again, I would only change the thickness of the IC from 2.75 to 2.5.
In this post are photos and links.
https://www.audiforums.com/forum/sho...d.php?t=147018
kpan
Oct 19, 2009 09:54 PM
Reiem125
Nov 5, 2007 08:51 AM
DurTTy
Aug 7, 2007 12:20 PM
6g72tt
Apr 30, 2007 10:28 AM
sooks
Apr 2, 2007 01:48 AM
