sheesh no wonder I was leaking washer fluid
Old Mar 31, 2009 | 10:57 PM
TheDavey's Avatar
Default sheesh no wonder I was leaking washer fluid
this thing was a pain in the neck. this pump doesn't exsist anymore. but i figured out a way to fix it with a cheap 20 pump from advanced auto. and about 5 bucks at home depot on rubber line and brass fittings. But yeah i think its broke pretty good. Don't know why I'm posting this. But I have no idea how it actually worked to begin with.
Old Mar 31, 2009 | 11:19 PM
andrewj654321's Avatar
yeah that just may be a problem.
idk how hard the ones on our cars are to change out but i had to change out the entire resevoir on my honda and it was a pain in the a**
Old Mar 31, 2009 | 11:35 PM
TheDavey's Avatar
well it seems like everytime you have to fix something simple you have to remove parts. that have nothing to do with it. all the drivers side headlight backings have to come out and the wiring harnesses as well as the thing that holds them. then the power steering resevoir has to move. thats just for the pump. im glad I didnt have to do it but it looks like to take out the resevoir you have to remove the tire. the inner fender panel and it'd probably be much easier to remove the fender too. i just hate the fact that the dealer told me that pump doesn't exsist anymore and you have to buy like 3 little retrofit clips for like 30 bucks just for little plastic things. to make the harness fit. I spent 5 at home depot and made my own. much easier.
Old Apr 2, 2009 | 06:11 AM
borninrussia3's Avatar
hmm i spent 27 when i replaced my pump got it from worldpak original oe pump and it was all plug and play too. i went through the wheel well though , took like 15 min.
Old Apr 2, 2009 | 06:12 AM
pardon my two "original"s
Old Apr 2, 2009 | 11:19 PM
TheDavey's Avatar
dealer had the same pump I bought from advanced for 25 bucks. but yeah. I didn't feel like taking the wheel well apart or lifting the car to remove the tire. It was just as easy. only took like a hour. But it was a pain in the ***.
Old Apr 2, 2009 | 11:44 PM
well it was 27 for pump, new pigtail , o-ring and delivery
Stearnsy
May 5, 2013 06:12 PM
loyolacub68
Aug 23, 2011 06:00 PM
chief
May 22, 2008 02:37 PM
vrso2
May 13, 2007 05:07 PM
apg96
Jun 28, 2006 03:41 PM
