Brake light problem.. What am I missing?
Old Aug 20, 2009 | 09:50 PM
Nathan Psy.D.'s Avatar
Default Brake light problem.. What am I missing?
I have a warning that my left brake light is out. Replaced the bulb and am still receiving the warning. I then switched out the 4 bulb housings and the left still does not work, but both will work when hooked up to the right side. Also checked the fuse near the dash, but it was ok and both aren't out. What am I missing here? I tried to search and couldn't find anything that has helped to this point.
Old Aug 20, 2009 | 10:29 PM
audi ops's Avatar
Does the turn signal work on the left, cause if it doesn't it could be the ground because you said putting the left on the right side worked so it shouldn't be the wire; correct? Or did you put the bulb in the right where the fog goes? But I'm gonna go with the ground
Old Aug 20, 2009 | 10:39 PM
Thanks for the quick reply. The other 3 bulbs work fine on the left side. When I put that same housing all 4 bulbs (including brake) worked on the right. When I moved the original right side to the left, only 3 bulbs worked again. Something is going on with that left side...
Old Aug 22, 2009 | 04:26 PM
DavidgotanAUDI's Avatar
Well all I can say is check the plus see if you habe had any shorting issues like a slight burn or a messed up pin. What bulb is it, turn reverse or a brake or running light??
Old Aug 23, 2009 | 04:20 PM
It's one of the 7528 bulbs (dual filament brake). Everything looks ok and works perfectly when switched over to the right side.
Lollare
Oct 26, 2014 04:07 PM
luciddream42186
Jan 25, 2012 08:13 PM
Konrad76
Dec 1, 2008 12:41 PM
smoovmusicdj
Aug 22, 2007 10:27 AM
brianblanks
Feb 4, 2006 05:18 PM
