Brand new brakes screech / squeak
Old Apr 1, 2006 | 04:18 PM
kgsolomon1's Avatar
Default Brand new brakes screech / squeak
I recently had the stoptech stage II kit installed, and even after doing the brake-in instructions, I'm having an issue. A couple weeks after I had them done they started to squeak or make a screeching sound when I stop. It only happens under 10, maybe even 5 miles an hour, but its very annoying and it is pretty loud. I took it back to the shop that installed them and they retorqued everything and said the rotors and pads were fine, so why are they making that noise?
Old Apr 1, 2006 | 09:05 PM
Cheese Eater's Avatar
Default RE: Brand new brakes screech / squeak
i had this on my stock brakes. i hate braking, but the only way i know to get rid of it is to use them, get your car to speed and use the brakes. if you are a cautious driver and plan your moves on traffic or an up coming off ramp, (i'm back woods, i do this too), just wait a few more seconds and give a meatier thrust to the brake pedal. my problem disapeared in a matter of weeks.
Old Apr 1, 2006 | 09:21 PM
kgsolomon1's Avatar
He I'm not cautious like that. I thought if I used them more it would go away, but its been a couple weeks and it hasn't changed.
Old Apr 1, 2006 | 11:08 PM
sooks's Avatar
i also have the stoptech kit, and im experiencing the same thing. The mechanic told me that its just like dust... and if you give it a couple hard brakes when you first stop it should quit...but its not really. i think its just the type of pad. for me its only when i lightly brake.
Old Apr 18, 2006 | 04:27 PM
kgsolomon1's Avatar
yea they are still squeaking and its pissing me off. Some guy said its cause they are a harder compound and the squeak means they are good, but I don't think I can take it anymore. Its not a soft squak, its really loud. Think if I changed brake pads it would make a difference?
Old Apr 18, 2006 | 05:19 PM
sooks's Avatar
I know what you mena man..it seems in the warmer weatehr mine does it more.. and its getting worse. I suppose cause mine are getting down..but theyre still 50%.. its annoying.
Old Apr 18, 2006 | 06:16 PM
Superdug's Avatar
SoCal Crew Member/White Devil
The guy I go through for all my audi raciung needs says that the pads are to soft and create so much dust that it causes a squeek. He says if you s upgrade the pads to a meallic pad the squeek and the dust should vanish.
Old Apr 18, 2006 | 06:22 PM
sooks's Avatar
but wouldnt that defeat the purpose of having good brakes.???
Old Apr 18, 2006 | 11:12 PM
kgsolomon1's Avatar
That's what I was told. The brakes are so good that they squeak...I thought he was crazy at first but he said if u get cheaper not as good quality pads the squeak goes away.
Sammy~D
May 16, 2011 05:56 PM
adam_schell2239
Jan 30, 2010 04:28 PM
wildgene789
Aug 17, 2008 08:16 PM
wahoos79
Feb 6, 2008 02:36 PM
Houndz408
Jun 27, 2005 10:09 PM
