Engine off balance?
Old 04-19-2009, 12:21 PM
a12gaugehug's Avatar
Default Engine off balance?
so kind of an out there question but the other day i did the darintake with a green filter and i got everything back together and sat there at idle revving it a couple times and i noticed as i held the rpm's at around 2-3 grand if felt like the motor was unbalanced or something. it was kind of vibrating the car. if i went higher the vibrations went away.
any ideas?
Old 04-19-2009, 01:34 PM
bottlecap's Avatar
double check all those electrical connections that cover the air filter and sensor and make sure everything is securely plugged in
Old 04-19-2009, 05:39 PM
i'll double check that but im pretty sure theyre on there good, i was thinkin maybe it had somethin to do more with bad motor mounts or something. like i said in a different post it feels like the motors going to go through the front of the car when i shift aggressively
Old 04-19-2009, 05:40 PM
oh and its got about a 100k on it so im sure its not quite to factory specs still
Old 04-19-2009, 10:18 PM
bottlecap's Avatar
could be that too...do you see any evidence of fluid leaking from the mounts?
Old 04-19-2009, 10:29 PM
drev500@aol.com's Avatar
ya your mounts are probably shot. But revving it with bad mounts wont cause that kind of vibration.
Old 04-20-2009, 07:30 AM
its not a terrible vibration, the car just seems to kind of shutter
DanaB6
10-11-2012 10:10 AM
jasondmaguire
07-25-2008 12:01 AM
machineman
03-17-2008 04:40 PM
tm2131
02-15-2008 11:47 AM
jliu
08-08-2006 05:01 AM
Quick Reply: Engine off balance?
