Modding with Warrenty (esp. chips)
Old Apr 14, 2008 | 02:42 AM
mizzike2555's Avatar
Default Modding with Warrenty (esp. chips)
Hey I would really like any help from anyone with experience moddin their s4 under warranty. I am getting a comrehensive warrenty and the allow slight mods (cat back,intake) but no wheel size changes or front mounts or anything extreme. What I am more conerned about is chips. Can I just buy second chipped ecu and change it back to the original before srvice? Can they tell? I was wondering if any one would even notive if I had new down pipes or anything or that nature.I wonder about diverter valves and the TBB's too. Any thoughts please.
Old Apr 14, 2008 | 07:45 AM
readimag's Avatar
Default RE: Modding with Warrenty (esp. chips)
lol only a dumb person could not tell if you got new downpipes, but you could always say your old one failed and fell. i amsure you could come up with a good reason to change all parts on a car. as for the ecu change no way to know cause you take off the neg cable of the batt to change it out so it clears the car of everything. I say you will be good cause k03's also fail and k04's are direct bolt on replacement and they "look" the same to the eye till you pull the engine.
Old Apr 14, 2008 | 10:10 AM
Brandon2000s4's Avatar
Ok is this warranty a factory warranty or an aftermarket warranty?
If it is an aftermarket warranty, and you arnt the orginial owner, then you can just say that it was like that when you bought the car.
Old Apr 14, 2008 | 04:02 PM
yesss4's Avatar
The Revo for the B7 comes with a device that allows you to switch the chip back to stock. Not sure if B5's require an actual swap of the chip (mine is just flash software)
Old Apr 14, 2008 | 11:36 PM
acamillo's Avatar
idk if anyone makes a ecu reflash similar to the conforti shark system available for bmw's, but I'm pretty sure its invisible to mechanics, and if they erase the flash and set it back to stock, you can reflash yourself in like 30 min.
phillyfan1290
Nov 19, 2007 05:27 PM
Darknight101
Jul 2, 2007 09:32 PM
MoPhillyBluez
May 11, 2007 06:55 PM
eboy44
Feb 28, 2007 02:03 PM
kourosH
Mar 8, 2005 01:30 AM
