O2 Sensor - P1113
Old Sep 27, 2007 | 02:09 AM
to3o's Avatar
Default O2 Sensor - P1113
I recently got a CEL (P1113 = Bank1-Sensor1 Internal Resistance too High) on my stock 01 S4. I searched the forums and found that it may be…
"Sounds like an open circuit. Check for loose and dirty connections to O2 sensor. .."
and that
“o2's are on the exhaust system get underneath the car…”
I would like to replace my O2 sensor(s). If there are four O2 sensors, how do I find the problematic one or do I need to replace all four? Where do you g[/b]uys buy O2 sensors from? I found this http://www.car-stuff.com/mmparts/aud...en_sensor.html. Are their prices reasonable (~$50)?
P.S. I am new to this forum, but I have noticed that everybody is extremely cooperative. Thanks in advance!
Old Sep 27, 2007 | 03:29 AM
2000Sforce.dtwaudi's Avatar
Default RE: O2 Sensor - P1113
your b1s1 is bad. That is passenger side front. Do not get them off that site. Also the one you posted you will need to solder in. Go to http://vastperformance.com/shop/prod...products_id=69
you are better off getting 2 at a time cause they go in pairs and if your in there do both.
Old Sep 28, 2007 | 01:53 PM
to3o's Avatar
Thanks 2000Sforce.dtwaudi.
Is it normal for a CEL (P1113) to disappear for a day and then appear again? Because it happened to me. Is this sign of loose connection somewhere?
Old Sep 28, 2007 | 05:52 PM
2k S4's Avatar
Yea, they do that, the sensor is failing, so you will need to replace it.
Old Sep 28, 2007 | 10:07 PM
ORIGINAL: to3o
not a loose connection you would be getting an open code. Your O2 is just on the fritz. Get both b1s1 and b2s1 and call it a day.
Old Dec 21, 2007 | 07:27 PM
tuzakey's Avatar
Sorry to revive a 3month old thread, but.... I'm seeing the same thing as the original poster. My 2001.5 S4 had the CEL come on while I was driving home from work the other night then before I could make to autozone to pull the code the light cleared, when I got to autozone I found P1113 and P1131 stored, I erased them and drove to work, then on the way home again the CEL came on, I'm guessing its the same pair of codes. I went and measured the resistance as described here: Diagnosing Oxygen Sensor Heater Codes but the passenger side is only at 8.3Ohm and the driver side is at 9.3Ohm, which sounds to be in spec. I've got a service contract that covers all of the electrical and powertrain so I'm not too worried (should I be?) Regardless, I'd like to have an idea of what I'm up against when I take it in.
Cheers,
-Ryan
azeezn
Dec 29, 2009 12:40 AM
hartsoe1
Feb 24, 2008 10:14 AM
Indiepunk
Aug 24, 2007 10:42 AM
Audi42005
Dec 12, 2006 02:43 AM
Eessfor
Feb 5, 2006 12:19 PM
