tons of questions HID's, K04's, alingment
Old Sep 8, 2008 | 11:16 PM
thatguy12484's Avatar
Default tons of questions HID's, K04's, alingment
so, finally got some time and money to put into this car. first off, i got the car wiht an HID conversion, but now when i turn the headlights on one side works fine, but the other one turns on for a minute but then turns off, any ideas why?? r maybe a wiring diagram of how it should have been converted. then curious what's the easiest way to do a k04 conversion, what all do i need and where can i get it cheap? lastly, does anyone do some semi agressive autoX, what kind of tow do you run in the front? thanks guys!!!
Old Sep 8, 2008 | 11:45 PM
02AvantImola's Avatar
Put a relay wiring harness on your headlights.. it stopped my flicker on my truck.
Old Sep 9, 2008 | 12:12 AM
lilnickx69's Avatar
what year is your s4?
cause i know from the b5+ all come with xenon hid's standard.
Old Sep 9, 2008 | 11:22 AM
Blue_S4's Avatar
cheap and k04 are like oil and water....they dont go together
Old Sep 9, 2008 | 11:55 AM
SourDieselS4's Avatar
Do the work yourself and you can be Stage 3- for under $3000 (turbos, inlets). Complete kits WITH fueling start around $5000 and go to about $9000, then add on another $3000 or so for downpipes and intercoolers. This is ignoring all of the "extra" things you may need to do "while your in there" or for relyability. HAVE FUN!
HID comes stock
Just did my first autox event this weekend i dont know enough to be able to change my allignment settings for better performance, i just upped the tire pressure in the back....
Old Sep 9, 2008 | 08:48 PM
drev500@aol.com's Avatar
not only toe but camber you would want to adjust too so you get the tires to lean. If I do remeber correctly when i aligned my car, the camber is non adjustable.
Old Sep 15, 2008 | 10:31 PM
DevilS4's Avatar
Camber is not adjustable stock. There are a couple companies out there that make heim joint control arms that allow complete adjustment of camber, caster, and tow. I had them on my last b5 and they worked great.
johnrpgparts
Mar 8, 2017 11:00 PM
johnrpgparts
Jan 20, 2017 01:55 AM
brewbiden
B8 Models
Feb 17, 2009 01:38 PM
WantanA6
Aug 10, 2007 03:45 PM
andrewdlarson
Nov 1, 2004 05:16 PM
