Voltage Regulator Controlled by the ECU? Is the ECU the car's main computer?
No way will it ever spike that high, Or I mean it could but there are at least three things in a series that would pop or blow before anything happens to the ecu. Are you asking that the ecu could be an indicator of a high voltage output, that would not be the case, your main culprits would be the normal electrical components.
Thank GOD for the ECu being OK. I'm asking if 18.5V @4,000 rpm (in neutral) can ONLY be attributed to a bad Voltage Regulator/Rectifier? (the car's in limp mode, and I can't see why a bad VR would do that at idle where a normal 14.4 volts occurs.)
