Sights N Sounds Upload and Post Video and Sound clips here. This forum is for video's pertaining to Audis, Racing (Street/Strip), Interviews, and Off Topic.
A4/S4 vss wire
Old Mar 6, 2007 | 02:10 AM
pentavolvo's Avatar
Default A4/S4 vss wire
I tried searchin, im putting nav in my 05 S4 does anyone know what color and where the vss wire is. Is it in the harness behind the radio or not. Thanks... BTW I tried searching with little luck
TIA
Old Mar 7, 2007 | 12:13 AM
TKneedsS4's Avatar
Default RE: A4/S4 vss wire
give me a split second gotta check my archives haha
Old Mar 7, 2007 | 12:19 AM
TKneedsS4's Avatar
Ok it didnt list 05 S4, howeve ri got info on 05 A4....
Speed Sense wire (aka VSS) brown/red or white/blue at the instrument cluster (blue plug).
However i dont know if that is the same as for the S4 most likley it is even if its not you are not gonna damage anything by testing it... maybe a blown fuse at worst. Hope it helps
Just looks for blug plug at instrument cluster and test each of those wires.... U trying to add Navi? if so what unit? if u odnt mind me asking
Old Mar 8, 2007 | 12:18 AM
pentavolvo's Avatar
a Kenwood, unit Ill post pics and the what not when I put it in. Its for a friend so I dont have access to an audi at the moment, is this plug on the cluster easily accesiable or do I need to pull the cluster, if so any help is much appreciated
Thanks
Old Mar 10, 2007 | 02:47 AM
TKneedsS4's Avatar
Not too familiar with the car. but with b5's i know if u take off most of the under dash you can acess it but im not sure on an 05... Good luck it shouldnt bee TOO bad. but then again who knows.
Old May 25, 2007 | 02:47 PM
Vector02's Avatar
I need to locate the VSS wire on my 06 B7 A4. Anybody have this data? Same as the 05?
Old May 25, 2007 | 02:59 PM
techbod's Avatar
post in the correct area and you might get an answer even I wont answer here lol
phatboyfromla
Dec 13, 2010 09:18 AM
Nevalite
May 9, 2010 10:54 AM
louisrobinson7
Dec 15, 2009 12:10 PM
clim2090
Aug 19, 2007 12:17 AM
mehansen50
Jan 27, 2007 01:09 AM
