Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
2012 A5 Cab Quattro Sway Bar upgrade ?
Old Nov 20, 2011 | 02:19 PM
ef1018's Avatar
Default 2012 A5 Cab Quattro Sway Bar upgrade ?
Have a new 012 A5 Cab Quattro and want to upgrade the sway bars. The OE rear is 19.7mm and there is a 21.6mm available..The front is 27mm ,as best I can measure,but there don't seem to be any upgrades available. I looked at S4 options as well and no larger bar is listed..
Any input,,thoughts,,suggetsions would be appreciated.
Old Jan 28, 2012 | 10:21 AM
ImTheDevil's Avatar
That's probably all you're going to find for now - that car is a new enough generation/design that the aftermarket hasn't had long to work with it. You could check with the dealer about an upgrade from the RS4/RS5 and see if it's compatible. Bring money though...
ECS Tuning
B7 Models
Mar 3, 2014 01:46 PM
ECS Tuning
Feb 28, 2014 04:25 PM
paul2lisbon
Oct 16, 2013 02:51 PM
imaudi5000
B7 Models
Apr 20, 2010 12:20 PM
AudiOso
Mar 31, 2007 02:07 AM
