Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
knocking/rattling noises
Old Feb 19, 2013 | 06:06 PM
phil_s's Avatar
Default knocking/rattling noises
any ideas , i've recently purchased my 1st audi , driven bmw for 5 years so used to the hard ride of run flats , but the 58 audi a4 tdi s line ive just brought is pants and will get shot if cant sort out the knocks and rattles , i get a knock/metallic clunk when driving over uneven ground or pot holes at any speed . sounds like front and rear knock , it actually sounds like its coming from the doors , like the strikers are not adjusted in enough causing the locks and strikers to rattle , but doors seem to tight when closed , this sound familiar to any one , also i get a squeak type suspension noise over bumps not sure if front or rear if any one knows if these a4's suffer from bad suspension component wear please let me know , there is also alot of general cabin noise/rattle type horrible stuff going on inside the car as if trims etc are loose , is this normal or should i set the sat nav to turn around and select cash back option !! ??? cheers to any wizards that might be able to help out a new b . dunka
Old Apr 7, 2013 | 12:12 AM
naturalscience42's Avatar
I didn't know Audi made the A4 in 1958?
Old Apr 21, 2013 | 06:39 PM
OHCGUY's Avatar
sorry bud, but the clunking/rattling noise is a non-fixeable defect. I bought a new 2012 S4 and they repurchased the car. Even offered me a new one but all the new ones on the lot had the same problem!
Old Apr 22, 2013 | 06:16 PM
Well first of all, a 2012 S4 is a completely different car than a 2005 A6. Second, anything, and I mean anything on a car can be fixed or replaced. It's just a matter of identifying the problem. Thanks for your input though.
phil_s
B7 Models
May 8, 2015 05:35 PM
sineo
Jun 11, 2011 07:38 AM
CelticWarrior72
Oct 25, 2010 09:06 AM
afstud6900
Oct 9, 2008 07:32 PM
AudiS4Newbie
Jan 17, 2008 04:23 PM
