Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
looseness in steering wheel
Old May 19, 2013 | 05:32 PM
rumb's Avatar
Default looseness in steering wheel
2001 A6 4.2
Just replaced all control arms, tie rod ends, new tires. (this problem existed before the work also)
The steering wheel itself has looseness or play in it. I don't mean the steering in general is loose or sloppy like when front end components are worn.
You can with hardly any pressure at all you wiggle the steering wheel back and forth almost 1/2 inch in total.
Any ideas where to look? Is there a clamp bolt on the steering column shaft to the R&P? It feels like the looseness in between the steering wheel and the rack.
Thanks!
Old May 19, 2013 | 10:24 PM
B5 Fanboy's Avatar
Maybe the steering box is bad?
JustWondering
B7 Models
Sep 11, 2011 11:17 AM
djdevvydev
Jun 14, 2010 03:13 AM
Audi S4 Turbo
Apr 22, 2010 10:42 PM
bosullivan
May 26, 2007 10:42 PM
