Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Lowered 03 A6 gets nervous in rear
Old Feb 16, 2010 | 01:30 PM
GYII's Avatar
Default Lowered 03 A6 gets nervous in rear
I had it on an alignment rack and it was right on spec.
With the 19's, it was baaad, with 17's and snow tires it feels better on dry pavement but if I drive where there's a slick spot of ice, the rear is out of control. It's scary. The alignment tech said it felt like something was loose on the chassis. But we can't see or feel any loose components.
It also tracks all over the place when there are grooves cut on concrete roads that aren't perfectly straight. The front is great! Not even much bump steer.
Any insights on this problem? Should I compensate for something with an out of spec adjustment?
Old Feb 19, 2010 | 12:08 PM
GYII's Avatar
Toed in on the rears too much. Also moved camber out to .5 degrees. Makes me wonder if they even checked the rears.
darrells
Feb 23, 2013 07:13 PM
darrells
Dec 9, 2012 06:17 AM
98A4TQ
Apr 6, 2007 02:21 AM
TeeTee
Jan 5, 2007 08:40 PM
west2005
Aug 27, 2005 12:48 AM
