Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Trying to diagnose clunking from the front
Old 08-16-2010, 12:48 AM
A4 2000's Avatar
In conclusion it was two upper control arms that were badly worn. I ended up replacing all 4 just to make sure. No more clunking!! I got them from this place for an awesome price and they even have a 1 yr. warranty. I highly recommend them. Check it out!
http://www.cxracing.com/mm5/merchant...gory_Code=CBKT
Old 08-27-2010, 08:17 AM
codan's Avatar
I get a clunking especially when pulling up a hill on a left hand bend. I checked and the left inner cv joint is very loose and rattly. The boot looks fine but the joint is definitely knackered. It doesn't seem to have got any worse in the last couple of years but I will tackle it one of these days.
Old 10-01-2010, 11:37 AM
MyAWDee's Avatar
was it hard to replace? i have a similar problem...
https://www.audiforums.com/forum/sho...=1#post1246737
Old 10-31-2010, 01:48 AM
B5LVR's Avatar
what kind of clunking is it cause I have a clunking sound in first and about a quarter way through second, I noticed today while lowering my car that my rotor on my front drivers side is really loose and has alot of room to move around but doesnt seem like the source of my clunkage.
Old 05-15-2011, 10:52 AM
blue5555's Avatar
Thumbs up upper control arms
I had the exact same problem ,jack the car up grab the tire and move it from side to side and watch your upper control arms, if you have any play then they need to be replaced. About $160 for 4 new upper arms and easy to do your self, and well worh it I did it yester day.Man what a diference but go get a full alinment when all done took me about 4 hours to do,good luck.
elduderino200
06-03-2015 01:26 PM
jhsoccerodp
11-07-2008 04:14 PM
Brandon2000s4
10-06-2008 04:35 PM
jonah5
08-21-2008 12:11 PM
willigd
09-27-2007 10:24 AM
Quick Reply: Trying to diagnose clunking from the front
