Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
What does tight suspension on a car feel like?
Old Mar 1, 2011 | 11:01 PM
Ruperorit's Avatar
Default What does tight suspension on a car feel like?
I just switched from a Mercedes sedan to their little roadster (SLK 320) and it drives so differently. I understand why the steering is tighter on sports cars, but what does it mean when someone says a car has tight suspension (in practical terms, how it drives)? What does a car feel like that has tight suspension as opposed to one with loose?
Old Apr 15, 2011 | 10:51 PM
sharper911's Avatar
A tighter suspension will have less body roll when turning, less of a feeling of 'diving under' when braking, and will 'lean back' less when accelerating.
This is advantageous because it typically means the car has a lower suspension, and therefore a lower center of gravity. This can be felt most commonly when turning, and high speed breaking.
A car with a loose suspension will be the exact opposite of a tight one. The advantage to this is that it allows more room within the wheel well for the tire to move and gives you a smoother ride.
If you need clarification on any of my rambling then let me know!
teddysart
May 1, 2011 10:04 PM
Deboraher
Feb 15, 2011 10:46 PM
Benji
Jun 27, 2010 10:40 AM
kittenherder
Nov 11, 2009 06:46 PM
a4autocrossr
May 25, 2005 06:39 PM
