VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Check engine light, misfire and no power on my 2.7t a6 codes just scanned with vagcom
Old Jan 6, 2009 | 03:05 AM
domenicostorino's Avatar
Unhappy Check engine light, misfire and no power on my 2.7t a6 codes just scanned with vagcom
Hello guys, my 2.7T was running normal and then all of a sudded the check engine light went on, the engine started shaking misfiring and kept running like that.
I had a similar issue with my 1.8T Passat and it was a faulty ignition module. The issue with my A6 feels just the same.
ANY HELP? PLEASE??? I scanned it with my laptop using the vagcom software and these are the results:
VAG-COM Version: Release 409.1-US
Address 01: Engine
Controller: 4B0 907 551 K
Component: 2.7l V6/5VT G 0003
Coding: 06612
Shop #: WSC 02325
4 Faults Found:
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
P1457 - 35-00 - -
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-00 - Please Register/Activate
16689 - Shareware Version. To Decode all DTCs
P0305 - 35-00 - Please Register/Activate
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Old Jan 6, 2009 | 05:56 PM
nemohm's Avatar
Selfexplanatory:
16686 - Cylinder 2 Misfire Detected.
Replace the ignition coil (make sure the spark plug is sound).
Or swap the coils between cylinders and monitor if the misfire follows.
Old Jan 7, 2009 | 06:51 AM
loach1's Avatar
P0305 also - misfire on no.5. Separate banks, so probably coils rather than EGT sensor (your other fault), and not the ECMs because they would have to have failed simultaneously.
Old Nov 8, 2009 | 10:43 AM
Originally Posted by nemohm
Selfexplanatory:
no, it was one of the ignition module, just as I suspected
Old Nov 8, 2009 | 11:02 AM
smmotavalli's Avatar
Hi sir;
I just want to buy an A4 (2.8 V6) the engine light was on. the dealer said to me it's nothing and it's because of coil and something like that. he said to me that I garanty the transmission and e checking for 90 days. I like that Audi, should I trust him! Might it be a serious problem for car? could you please help in this regard!
Best
Old Nov 8, 2009 | 11:03 AM
I should mention that that! the car runs great and there is no problem or misfiring or any thing else that I could see.
Old Nov 8, 2009 | 11:05 AM
Also, I recognize that they cleared the codes of that car and right now the engine light is off.
I look forward to hearing from you as soon.
Best
Old Nov 11, 2009 | 11:02 AM
hxgaser's Avatar
Thread highjack! But I will respond anyways. Wait until the CEL comes back on and have him show you all the trouble codes. Then do the research on what the codes are. Never buy the darn thing if the CEL is on and you don't know what the codes are.
Being an Audi owner, I wouldn't take one even if some one paid me money for it
Old Nov 12, 2009 | 12:56 AM
Keithr726's Avatar
From my experience with recent Audis, once you replace spark plugs and coils you will have a reliable car. Coils are fairly cheap at $30ea, or check your mail for the coil recall.
RedA4guy
Jun 15, 2013 08:33 PM
kiteoregon
Mar 16, 2013 04:12 PM
bmoore98A4
Dec 5, 2011 02:40 PM
jfree212
Feb 4, 2009 09:14 PM
Cranky Bastard
Nov 22, 2007 12:51 AM
