VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
No windows Vag Com scan
Old 02-20-2014, 09:00 PM
EvoTillIDie1's Avatar
Default No windows Vag Com scan
Long story short. Had my turbo timer installed. After that ALL and ONLY the windows stopped working. I have a 2000 Audi A4 1.8t Quattro 5 speed and it's getting warm out so opening the windows would really help. My friend said he tapped into the central locking but if I use my key in the driver's side door I can bring all the windows down and up. Can you guys tell me what might be the problem with this? The central locking codes were clear to see which one would come up again seeing how last month someone tried to break into my baby & broke the locking mechanism on my driver's door. Thanks in advance.
VCDS Version: Release 12.12.0
Data version: 20130910
Wednesday,12,February,2014,17:14:26:26926
Chassis Type: 8D - Audi A4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 058-906-018-ATW.lbl
Part No: 4B0 906 018 P
Component: 1.8L R4/5VT G 0006
Coding: 07201
Shop #: WSC 08126
VCID: 2E58B81CEA7E6B6E36F-5120
No fault code found.
*These were cleared*
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C3C62D48CC2E9FE68B-5120
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D56
Coding: 00140
Shop #: WSC 06335
VCID: 2D5ABF10E77810760F5-2578
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-00 - Blocked or No Voltage
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 K
Component: Airbag Front+Seite 0002
Coding: 00104
Shop #: WSC 06335
VCID: 3E78885C3A1E9BEEA6F-515A
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 CX
Component: B5-KOMBIINSTR. VDO D17
Coding: 02244
Shop #: WSC 08167
VCID: 830EB9A8917CB606091-5120
2 Faults Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to Plus - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 15215
Shop #: WSC 06335
VCID: 4084F6A440EAED1ED43-4ECA
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
VCID: E0C49624602A0D1E743-4B00
1 Fault Found:
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00207
Shop #: WSC 06335
VCID: 244C5A34B4B2D13ED0B-4AE6
End ---------------------------------------------------------------------
Old 02-22-2014, 01:49 PM
No one can help me?
stevendsouza
12-05-2013 12:45 PM
jsandlin491
11-24-2013 10:56 PM
Rowdy_Audi
06-14-2012 07:02 PM
striker451
09-04-2009 03:44 PM
meanse
11-13-2007 03:04 AM
Quick Reply: No windows Vag Com scan
