VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
ran vagcom and found problems
Old May 11, 2006 | 03:26 AM
Jits7's Avatar
Default ran vagcom and found problems
Thanks for the help in advance,
I did a full scan and the results :
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 906 266
Component: 2,8l V6/2V MPI OBD2 D03
Coding: 01051
Shop #: WSC 00000
2 Faults Found:
16785 - EGR System: Insufficient Flow
P0401 - 93-00 - Unknown Error Elaboration
16845 - Fuel Level Sensor Circuit: Implausible Signal
P0461 - 68-00 - Cylinder 1
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 F
Component: AG5 01V 2.8l2V USA D80
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 G
Component: ABS/EDS BOSCH 5 7590
Coding: 0265109001
Shop #: BB 37590
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 F
Component: A4-KLIMAVOLLAUTOMAT_D64
Coding: รถ
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 035 G
Component: B5_KOMBIINSTRUMENT D04
Coding: 00262
Shop #: WSC 06311
End -------------------------------------------------------
Any idea on how to fix any of these problems or sugesstions would be much appreciated thanks,
josh
Old May 11, 2006 | 05:06 AM
BadLuckAudi's Avatar
Default RE: ran vagcom and found problems
maybe bad o2 sensor and bad fuel level sensor
Old May 11, 2006 | 08:17 AM
techbod's Avatar
Default RE: ran vag com and found problems
the engine wasn't up to normal temp when you did the scan by your read out so many sensors gave out poor readings which would be normal, I recommned you do the test with engine running when the engine is piping hot after a good run
Old May 11, 2006 | 08:34 AM
david9999's Avatar
I'd clear the codes, run the car for a week and see what if anything comes back.
Old May 11, 2006 | 07:57 PM
Jits7's Avatar
im gonna clear the codes and do it again thanks everyone ill post the results
Old May 12, 2006 | 12:30 PM
Jestnomen's Avatar
6th Gear
The fuel level sensor error is pretty normal. I did a write up:
https://www.audiforums.com/m_20295/tm.htm
theunknownprince
Apr 16, 2011 10:52 PM
exequiel3k
Aug 22, 2010 12:49 AM
nm3210
Nov 26, 2008 07:05 PM
mypreludeisred
Jul 31, 2006 09:30 PM
enenen
Mar 18, 2006 08:19 PM
