VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Reprogram ECU/TPS with vagcom ?
Old Apr 25, 2008 | 10:13 PM
carlv's Avatar
Default Reprogram ECU/TPS with vagcom ?
Can you do this with the vagcom or does it need to be taken to a dealer?
Old Apr 26, 2008 | 02:41 AM
onepoint8tee's Avatar
Default RE: Reprogram ECU/TPS with vagcom ?
Your question makes no sense.... Rephrase it.
Old Apr 26, 2008 | 07:27 AM
ImTheDevil's Avatar
Depends on what you mean by reprogram - if you mean "remove CEL, clear codes, etc" then yes. But if you're talking about a reflash for a more performance-oriented programming, no - that requires spending money for a new chip.
Old Apr 26, 2008 | 09:27 AM
EOD5's Avatar
yes you can, your question does make sense
one of the values you can adjust allows you to change the number and that will adjust the idle
Idle Speed Adaptation:
With engine warmed up, at idle:
[Select]
[01 engine]
[Adaptation - 10]
Enter channel 01
Enter an adaptation value between 124 and 132
[Save]
jaemako56
May 24, 2011 10:24 PM
caliman
Mar 5, 2011 07:10 PM
SAudi
Dec 29, 2010 12:36 PM
auditt225
Feb 14, 2007 02:19 PM
bigbird
Jun 30, 2006 02:18 PM
