VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Vag com Code reading help please
Old Mar 21, 2017 | 05:49 AM
Tallyj89's Avatar
Exclamation Vag com Code reading help please
Hi Thank you for reading, A bit about the car its a 2004 audi a3 tiptronic. bought it with a limp mode issue . found this to be clogged turbo veins i have no replaced these and that issue has now gone. however the car is very temperamental ... If i was to drive it from cold it will drive ok, however when the car seems to get warm i will attempt to pull off from a standstill and the car will hesitate dramatically (not the normal automatic) i will move my foot on the accelerate slightly and all of a sudden bam!!! its off like a rocket however this becoming quite dangerous to drive now as i am unsure if to pull out on the roundabout now or not... please help,
These are the codes that i have come up when running VAG,com.
the EGR has been deleted so I know thats an error code but the other i don't..
Thank you
Tuesday,21,March,2017,09:43:56:06598
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
Ross-Tech: Home
VIN: WAUZZZ8P44A106614 License Plate: AUDI A TURBO
Mileage: 201460km-125181mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P44A106614 Mileage: 201460km-125181miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 AT HW: 028 101 145 3
Component: R4 2,0L EDC G000AG 5689
Revision: 12345678 Serial number: AUX7Z0C9FNQ019
Coding: 0000078
Shop #: WSC 06435 000 00000
VCID: 75E1EE931CD8F0E9C0-8020
2 Faults Found:
16618 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition)
Freeze Frame:
RPM: 2394 /min
Torque: 278.0 Nm
Speed: 94.0 km/h
Load: 72.9 %
Voltage: 14.36 V
Bin. Bits: 10101100
Absolute Pres.: 2213.4 mbar
Absolute Pres.: 2590.8 mbar
16785 - EGR System
P0401 - 000 - Insufficient Flow
Freeze Frame:
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 041 C HW: 02E 927 770 G
Component: GSG DSG 0623
Revision: 02100224 Serial number: 00000310270092
Coding: 0000020
VCID: 122BB50F0D7647D145-8046
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
VCID: 3A7B3DAF75465F91ED-806E
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
Component: KlimavollautomatH12 0150
Revision: 001354 Serial number: 8P0820043F
Shop #: WSC 00000 000 00000
VCID: 2F6D1CFBBE048A394A-807A
1 Fault Found:
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 181
Mileage: 150182 km
Time Indication: 0
Date: 2013.11.16
Time: 08:10:16
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000190054
Coding: 01884F00A2141000000000000000000000
VCID: 3B7538AB7A7C6699F6-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
VCID: 45815E530CB8206990-8010
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H10 0020
Coding: 0011142
VCID: 7BF5F8AB3AFCA699B6-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0110
Revision: D07 Serial number: 2249CD07001680
Coding: 0000403
Shop #: WSC 00999 067 57207
VCID: 3C773BB77F7261A1FF-8068
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 240010390642E6
Coding: 3F0F0B42070101
VCID: 2643F9DF91FECB71B9-8072
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 216
Time Indication: 0
Date: 2017.03.16
Time: 10:58:22
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D07 Serial number: AUX7Z0C9FNQ019
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 397922A370405489E4-806C
2 Faults Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.10 1202
VCID: 2E5301FFB90E833141-807A
1 Fault Found:
02441 - Yellow Malfunction Lamp in Instrument Cluster
013 - Check DTC Memory - Intermittent
Freeze Frame:
Mileage: 1440 km
Temperature: 8.0°C
Voltage: 12.00 V
Voltage: 11.90 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
VCID: 79F9E2A330C09489A4-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
1 Fault Found:
01134 - Alarm Horn (H12)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001083065
VCID: 70EFDF8763BAD5C113-8024
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 199
Mileage: 200738 km
Time Indication: 0
Date: 2063.15.31
Time: 31:63:63
Freeze Frame:
Temperature: 5.0°C
Raw, Form. N/A: 000 000 000
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 199
Mileage: 200738 km
Time Indication: 0
Date: 2063.15.31
Time: 31:63:63
Freeze Frame:
Temperature: 5.0°C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
1 Fault Found:
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H55 0400
Revision: 19S Serial number: AUZ5Z4C5339060
Coding: 0001001
Shop #: WSC 00539 210 08758
VCID: 6FEDDCFB7E84CA390A-803A
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
VCID: 2B5508EB8A1CF61966-807E
End-------------------------(Elapsed Time: 01:50)--------------------------
akielb
Apr 4, 2007 04:40 PM
FaenaAzul
Sep 19, 2006 10:05 PM
gilee_8
Nov 28, 2005 02:17 AM
Hecareth
Apr 2, 2005 05:24 PM
blades
Oct 8, 2004 09:04 AM
