VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
vagcom k1 : short to ground problem
Old Jan 8, 2008 | 09:21 PM
TSRgeneral's Avatar
Default vagcom k1 : short to ground problem
So my car was in an accident and some controllers broke. I needed to vag my car and see the cel's. When plugging my vag com in I was getting an error "No response from controller".
This happened even in auto scan and couldnt seem to plug any codes. I thought i was toast. Someone had connected the postive and negative ends of some jumper wires on reverse tottaly shorting out the car.
I thought my ECU or something was fired, as this is really bad. In conjuction with my broken vagcom i thought i was lost. So i started reading and found that the Radio is the first thing to disconnect when you get a k1 : short to ground when testing to see if your vag com acutally works.
I unpluged the radio and like magic my vagcom works again and i was able to diganose my car. I checked the fuse on the back of radio, fine. Then i checked the other fuse on the fuse panel #42 to be exact. Not blown either. My radio doesnt turn on at all, it is just dead. a dead radio really sucks as all i listen to now is my DV sound and the revs.
How do i fix this problem ... Do i need a new radio. It is unpluged now, but how do i test and make my radio work. Thanks in advance,
Old Jan 9, 2008 | 04:30 PM
TSRgeneral's Avatar
Default RE: vagcom k1 : short to ground problem
My radio is still dead. I cannot seems to fix it..
Am I going to need a new radio or what? If this happened to anyone, please post as really need some tunes !
Old Jan 9, 2008 | 07:05 PM
auditech79's Avatar
TT radios suck, they always break. 99% chance you need a new radio.
Old Jan 10, 2008 | 01:03 AM
TSRgeneral's Avatar
aw ****. Whats the best stock replacement ?
I want something that works with my CD changer
Old Jan 10, 2008 | 02:35 AM
rayveedub's Avatar
check fuses.
Old Jan 10, 2008 | 10:48 AM
225tt's Avatar
I had a problem just like this when I lost my "control module for central locking" Do you have a roadster or a coupe? Is anything else not work inside the car as in the interior lights, or door locks?
Old Jan 10, 2008 | 06:09 PM
auditech79's Avatar
The stock ones aren't that expensive (made by panasonic) I would say its less than $250 from the dealer for a re-manned unit.
Old Jan 13, 2008 | 12:00 PM
TSRgeneral's Avatar
Got everything fixed. Found some fired fuses and got the radio working.
What a headache, but im glad its all fixed up
sandman7
Dec 30, 2018 09:21 PM
moneyfresh
Oct 16, 2012 05:30 PM
Torsion'sA8
May 25, 2011 06:30 PM
drobrt
Feb 8, 2011 01:07 AM
kbulava85
Jul 8, 2010 08:34 AM
