Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
Tire choose_which one?
Old Jan 1, 2022 | 08:24 PM
alozcarney's Avatar
Default Tire choose_which one?
So it’s about to time to replace tires and I thought it’s a good idea to create a thread to discuss budget tires. Anyways I did little research here https://tireer.com/how-long-does-it-...change-a-tire/ about the best tires and found that Venom Power Terra Hunter X/T is the best one.
So how it will be?
looking for your suggestions
Old Jun 12, 2022 | 10:28 AM
jeksonpip's Avatar
Don't forget about tires, Tires wear out in real time. Tires heat up in real time. The tire carcass bends and heats up locally, it's all something to keep an eye on. Director of Development forza horizon 5 rare cars Dan Greenwalt, Tire gases heat up as a result of the carcass heating up, and gas pressure increases as a result of the gas heating up. All systems are interconnected. Therefore, it is worth buying and choosing only quality tires.
Old Oct 4, 2022 | 04:20 AM
HungryWolff's Avatar
Don't make my mistake. And don't buy a car that will require special wheel or tire radius. Only when I managed to buy a used car from a reliable manufacturer, I was able to breathe out and relax. Before that I was running along Toronto till my socks burned, looking for the appropriate tires that would suit the wheel!
Old Apr 20, 2025 | 01:28 PM
Marrin193's Avatar
I have absolutely the same problem, can you recommend me something good right now? Probably someone is able to do it here. Thanks
lespaul2510
Jul 12, 2022 05:50 PM
Gman 56
Jul 24, 2013 05:42 PM
saintforlife
Aug 25, 2008 09:13 AM
audiS4jls
Jan 30, 2008 07:56 PM
EvilA4
Oct 9, 2006 11:17 PM
