Engine power sucks, replaced MAF, didn't help - engine codes inside...
I replaced my MAF thinking that it would solve the problem because I was getting "Bank 1 Too Lean" type codes - research on this forum indicated that it was usually due to a bad MAF. I also had to replace my Engine Coolant Temp sensor, which went fine (after I got the right part).
Well, after replacing the MAF and ECT, I still get the following codes:
P1136 - System too lean in bank 1
P1565 - Idle Speed Control Throttle Position lower limit not attained
P0116 - Engine Coolant Temp.Circ Range/Performance
I cleared them today and we'll see what comes back, but since I replaced the MAF, is it likely that the first two codes are due to a vacuum leak?
Thanks a bunch.
Thanks a bunch.
Thanks again.
domenicostorino
11-12-2009 12:56 AM
ZGSON
09-28-2007 07:23 PM
gTT
05-12-2007 09:51 AM
02DolphinA4
01-04-2007 12:35 AM
